Reply
digitalgypsea
Follower
Orbi RBR50 Voice Stopped Working After Update
My Orbi recently did an update and my Satelltie staion (ORB103) with voice (Alexa) no longer allows voice commands ot plays music (audio by Harman/Kardon).  All I get is a message that says can nt connect to Alex, try again later and this has happended no less than 20 times.  There is no Amazon/Alexa setting anywhere in the app, just the setting to connect to Amazon and it fails (see below for detailed desctiption), but no where to check or verfy Amazon/Alexa credentials.  Of course, my warranty is out of date, even though they sent me an update that broke my perfectly working mesh system.  Any ideas out there in Netgear land?
Go to Orbi app, select voice controls, after 10 seconds or so an error pops up "Orbi, Something went wrong. Try again later"  and thats it, over and over and over again!!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi RBR50 Voice Stopped Working After Update
Has a power off for 1 minute then back on been performed since last update?
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.17.12
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 61 views
  • 0 kudos
  • 2 in conversation
Announcements
