- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 bricked during update to 2.3.5.30
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried hard reset and it was unresponsive as well. Tried 30-30-30 and no luck. Unable to perform TFTP because when I plugged one end to PC and other end to RBR50 the computer doesn't recognize it's plugged in to a router or network. The network icon has an X.
Tried this method and it doesn't work either. https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Ran out of options already. Router is out of warranty so no RMA. This is a solid brick???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 bricked during update to 2.3.5.30
@Retired_Member wrote:
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30,
I guess you won't be doing any manual updates again...??
Possibly step the FW back? With those numbers I can't tell if you went back or forward. Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router was on firmware 2.3.1.60. .....
Are you sure that the Router was on 2.3.1.60? When was the last time you updated the Router? If you were on 2.1.x.x then you needed a stepping stone (2.2.1.210) to go to 2.3.5.30, this can be a possible reason for the "hanging status" that you're seeing.
I tried hard reset and it was unresponsive as well. ......
So what happens if you stick a pin in the Router's reset button for 15 seconds? Won't the power LED start blincking amber?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you use Windows built in TFTP or NGs TFTP program?
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unresponsive. The power green light is solid and no ring light on top. Unable to get router into recovery mode...green light stays solid green.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
And pressing the reset button for only 15 seconds doesn't result in any top ring LED coming on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the regular factory reset process doesn't work, @michaelkenward described an undocumented way to get an Orbi to factory reset:
Press paperclip in reset hole for 30 seconds
Keep pressing paperclip while removing power
Keep pressing paperclip for another 30 seconds while apply power
Is this the 30-30-30 that people speak of? If so, "My Bad"
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am unable to proceed forward or even go back to the original firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router was on firmware 2.3.1.60. .....Are you sure that the Router was on 2.3.1.60? When was the last time you updated the Router? If you were on 2.1.x.x then you needed a stepping stone (2.2.1.210) to go to 2.3.5.30, this can be a possible reason for the "hanging status" that you're seeing.
I tried hard reset and it was unresponsive as well. ......So what happens if you stick a pin in the Router's reset button for 15 seconds? Won't the power LED start blincking amber?
Nothing happens when I poked the reset hole with a paperclip. Tried holding it for a minute and still nothing...done it several times already. LED remains as a solid green light. It doesn't turn to amber on the RBR50. The RBS50 do turn to Amber so I'm guess the satellite isn't bricked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Did you use Windows built in TFTP or NGs TFTP program?
I actually tried both Windows TFTP and NG TFTP. There is no response from the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:And pressing the reset button for only 15 seconds doesn't result in any top ring LED coming on?
Nope...no ring light at all. The power ON green light remains green. Seems like the router is not communicating and not responding to any commands.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ran out of options already. Router is out of warranty so no RMA. This is a solid brick???If the regular factory reset process doesn't work, @michaelkenward described an undocumented way to get an Orbi to factory reset:
Thanks for your input though...yes this is the 30-30-30 method that people mentioned on other threads. Done it and nothing happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I am 100% sure my router was on 2.3.1.60 because I read the important part of the firmware update before I proceeded with the router. I even double checked to the current firmware yesterday.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems that the RBR is just bricked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might see if Amazon or eBay have some used ones if you still want to keep with Orbi.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
If you still have not resolved your issue and if you still have your router, try this.
I was following the TFTP guide with the Netgear client: https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
after step 5 I did the 30/30/30 factory reset. First I held the reset button until the power LED was blinking 30 times. Afterwards, when still holding the reset button pressed, I disconnected the power cable and waited 30 seconds. Finally when still holding the reset button pressed, I connected the power cable back. Now the power LED was red and I still held the reset button until the power LED was blinking 30 times. When I released the reset button, the power LED was blinking by itself, and I proceeded from step 8 in the TFTP guide.
The router is working fine now, hope this helps you or someone else in need.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had the same problem with my RBR50.I tried everything :30/30/30 reset, TFTP client...nothing worked. I noticed one thing :
Every time I pushed the reset button with the pin and connected the power, the power LED turn solid green,then solid red( which means the firmware is corrupted) and flashing red 7 times and solid green after that.
Does it mean my RBR50 totally bricked ?
Any suggests?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would contact NG support to see what your options are.
@Lucas88 wrote:I have had the same problem with my RBR50.I tried everything :30/30/30 reset, TFTP client...nothing worked. I noticed one thing :
Any suggests?
- Mark as New
- Bookmark
- Subscribe
- Permalink
what changed between message 16 to 19???
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am now afraid of doing updates on the RBK50. I will wait a month later to do it in case the update is bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The situation I had was a bit different. I didn’t get any lights to come on no matter which button to press....except for the power light which was on. Other than that there was absolutely no response from RBR50. I have since recycled the RBR50 but kept the satellite unit which I was able to reuse as an additional satellite when I bought a new set.
it's best NOT to perform manual updates at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The best way to do updates is to do manual download of FW files from NGs support site. Use a wired PC and connect it directly to the RBS and update the RBS first then connect to the RBR and load the FW lastly on the RBR using the unpacked .zip FW files. Use IE11, Firefox or Opera to do the updates thru the RBSs/RBRs web pages. Theres been some bad experiences coming from users using the auto update FW feature on the RBRs web page. Use the manual method seen on the FW update feature page.
I recommend after the RBS and RBR are updated, factory reset the system and setup from scratch. Been doing this way for a long time. Have not bricked any of my routers or satellites using this process. Works well and is a safter method.
There is newer FW out there. However if your system is working, let it go for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The best way to do manual updates is NOT. Leave it alone. That's all you had to say. Rattling on is not required
- Mark as New
- Bookmark
- Subscribe
- Permalink
so... what is the point to have your RBR50 updated? To my understanding, the updates are supposed to fix the problems, not to create the problems. NETGEAR should have some way to unbrick the RBR50 or a secure method to update the firmware.
I have been with NetGear since WNDR3700 to NighthawkAC1900. I never had any problems before, but RBR50. I think it is time I should try some other brands.
