Orbi WiFi 7 RBE973
Reply
Orbi RBR50 disconnects from FIOS internet
masteraleph
Follower
I've been having an issue where my Orbi system loses its internet connection, sometimes once a day, sometimes every few days, occasionally even multiple times on the same day.  This gets fixed if I restart the router, and the internet light on the FIOS ONT never seems to change.  As far as I can tell, the only Verizon device that I have is labeled as I-211M-L, which I think is an ONT only (possible that it's also a router, but it doesn't seem like it?)  Is there a way to stop this?
Orbi is on 2.3.5.30 firmware.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi RBR50 disconnects from FIOS internet
happens with both wireless and wired devices?
Can you access the RBRs web page when this happens to check the status?
ALso power OFF The ONT system for 1 minute then back on.
Your ONT is just an ONT, no router built in.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 466 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
