- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 dropping WiFi only since Sunday 28/3/21
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Any help would be much appreciated.
My RBR50 has started dropping the Wifi only since Sunday everyday at roughly the same 12hour intervals srangley enough, around 06:50 & 18:50 everyday. The wired connection stays up all the time.
RBR50 connected from Virgin Media Hub 3 in modem mode.
Firmware version V2.7.2.104 , The WiFi only restores once I've reset the Orbi. I've tried resetting the Hub3 only and waiting but the Wifi doesn't restore.
I've been using this setup ok for over a year with no issues, nothing has changed on setup .
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@alanbruno wrote:I've been having this same problem, however I haven't seen anyone mention that this WiFi connection dropout has been happening since updating the Orbi's firmware, as is my case. I received an email from Netgear on Sunday (the 28th) telling me "We've Enhanced Your Product's Security. Please Update to the Latest Firmware." I did so--up to version 2.7.2.104--and ever since then we've lost WiFi connection at least twice a day.
I am at a loss as to what to do. Needless to say, WiFi dropouts are untenable with us working from home. Is it possible to go back to the previous firmware? We had no such problems before this "update."
thx
Mac OS 11.2.3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 dropping WiFi only since Sunday 28/3/21
I've had the same issue, I can use the internet if I use a VPN, but without it nothing. Have to keep re-booting to get it to work. No issues at all until the latest update. DNS Server issues I thing according to the Windows 10 Help
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mont999 wrote:Hello,
Could you please clarify:
- WiFi devices actually lose the connection to the Orbi, or
- They remain "connected" but have no internet?
When this happens, is there a device wired to the Orbi that can display the Orbi web interface Attached Devices page?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
thx
Mac OS 11.2.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
thx
Mac OS 11.2.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okee-doke. I disabled the traffic meter. We'll see how things go.
Thx!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue here with ny RBR50 but the WiFi drops appear to occur at 24 hour intervals, around 10:00 PM at night. I was hoping this was a problem with the latest firmware update but, even if it is, checking for Firmware updates now doesn't work and results in an error message.
Netgear has really screwed the pooch with this one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear decides to help us.
ab
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
@alanbruno wrote:
Okay, well that didn’t work. In fact it’s exponentially worse. Our WiFi has dropped out four times in the four-odd hours since I’d deactivated it. As soon as I get this cat off my lap I will be returning to my computer and reactivating it in hopes of reducing the dropout rate back to once a day or so...until
ab
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi--
So many questions! First off, I apologize for that last post of mine. I wasn't finished with it but somehow it was sent. Secondly, I was off looking into the traffic meter again when it was sent. In that time the WiFi dropped out twice! BUT, when I finally got back to the traffic meter I found it still activated! All I can tell is that I hadn't click "Apply" when I first deactivated it; I merely closed the window. So I'm hoping NOW ithat I clicked "apply" it's truly deactivated because the dropout rate was really increasing.
Anyway, for you rquestions, in order of their apearance:
--A reset/setup from scratch has NOT been performed
--I'm confused about the satellite question. The router's firmware is the issue here, no? My computer is talking to the router (at an unobstructed 10 foot distance). Beyond that, are you saying AT LEAST 30 feet should separate the RBR and RBS? Yet you say "depending upon the building materials" Do you mean those that are between the RBR and RBS? And if it's, say, a brick wall they should be closer?
--2.4Ghz is on "Auto. 5Ghz is "48"...dunno what that means
--The "Other Networks" menu shows several other neworks but I can't imagine who they are. I mean, we're in a single family home on a block with only single families so I can't imagine we're picking up the whole block's networks.
That about covers it. The WiFi is still activesince I "APPLIED" the traffic meter disablement.
Back to you
ab
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, let try hoping for TM that if it's now disable, see if this helps with your problem first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Turned off the traffic meter too after catching up on post, all good for me so far for 2 plus hours , thanks for replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same thing but a friend/colleague helped me to a partial solution. I do not use the Traffic Meter so the other work-around wasn't applicable. It seems to be the daylight savings. Go into the Administor console, disable Daylight Savings and set the timezone on an hour ahead. Has worked reliably for over 24 hours now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Of course, would make sense with problem starting on Sunday
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey--
~12 hours since I disabled the TM (and hit "apply" 😛). So far, so good. Fingers crossed. My wife has an *extremely* important Zoom call this afternoon and her WiFi card doesn't cut it, as you can prolly imagine.
Thx again
ab
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to safe off a backup configuration to file for safe keeping on the RBR. Saves time if a reset is needed.
Enjoy.
@alanbruno wrote:Hey--
Thx again
ab
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will...as soon as you tell me where it is! I am not the most highly astute tech dude around, tho I try. Which settings would these be and what is their location? Back somewhere near the TM, I'm guessing.
thx...again!
ab
- Mark as New
- Bookmark
- Subscribe
- Permalink
Under Advanced tab/Administration/Backup Setting.
@alanbruno wrote:I will...as soon as you tell me where it is! I am not the most highly astute tech dude around, tho I try. Which settings would these be and what is their location? Back somewhere near the TM, I'm guessing.
thx...again!
ab
