- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 frequently losing connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 frequently losing connection
@MrTWA wrote:Same issue, started Sunday morning after daylight savings change. Having to reboot 1 to 3 times per day. Tried downgrading firmware - Didn't work. Tried factory reset - didn't work. Tried changing NTP server - didn't work. WTF? I have not had this issue before with this product and wouldn't expect to, WTF?
FYI....one of the moderators here have reached out about this. You may want to do the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For what it's worth I can verify the same thing is affecting the RBR40 model with firmware version 2.6.2.104. I knew something was hinky with DNS but had continued to blame Spectrum for this, until I read the Orbi Dropping DNS post. The symptoms and the first workaround fix is exactly what I'd discovered worked.
So, please Netgear, do not forget about the RBR40 on this problem as well. It doesn't show up on your list above, though that is what I have:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having the same issue everyone else has reported. I beleive this issue started after DST. Please provide a fix ASAP. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
System became totally unstable due to .104 software which was written by a top moron.
Fix is stop using netgear NTP server.
Use time.google.com instead.
You cannot use the App for this either, use a web browser on your iPad or laptop.
The App is completely useless. Probably written by the same moron who wrote the .104 code.
It's a pity crap software makes such a potentially nice system totally worthless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also don't use Traffic Meter was one report that NG seemed to acknowledge by NG to one user was the cause of this problem. Others reported seeing same and having better results after it was disabled. Good Luck.
@JJ126 wrote:System became totally unstable due to .104 software which was written by a top moron.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been experiencing similar issues since the same firmware release was loaded. The only way I've been able to restore access to the internet, is to login to my Orbi, Select "Internet" then click the "APPLY" button. Within a minute everything comes back online.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can use this for options to work around the issue (Option I is probably the one you want):
https://www.reddit.com/r/orbi/comments/m5l3vk/orbi_dropping_dns/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lost of ways to temporarily relieve the problem.
- Reboot the router
- Reset the DNS settings (it doesn't seem to matter which option you choose or what DNS servers you popint to)
Essentially re-apply *anything* that causes the router to refresh it's network settings seems to work for a few hours.
Somewhat longer term solution is to go back to an older version of firmware (note: if you have a mesh network - you only need to rollback the router itself - NOT any of the satellites). I went back to the .102 version and it has been stable for roughly a week.
There are threads that describe using Voxel firmware but I have not tried that source.
I have been told Netgear is working on the issue so I expect at some point in the next ~days(?) there may be a new version that is designed to address this problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What "fixed it" for me was changing the NTP server to something other than Netgear's (time.nist.gov, I believe) AND unchecking the "automatically adjust for DST" (not sure of the actual wording) option. My internet was solid for at least 2 days straight after I did that. I recently picked up an EdgeRouter and put my Orbi into AP mode so I couldn't tell you if the "fix" is still working or not, but it definitely looked promising.
I'm actually kind of grateful for the firmware bug. I've been eyeing an EdgeRouter for quite some time and this debacle finally pushed me to make the purchase, even with the additional $20 "COVID tax". I now get A's all across the board when doing a DSLReports speed test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/Orbi/Orbi-randomly-stops-traffic-to-devices/m-p/2073261#M117231
you are not alone. Same to me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it worked out for you, but my configuration had NTP using time.nist.gov and two openDNS static servers configured when I started experiencing the failures.
My guess is that by changing your NTP settings you actually forced the router to reset its network stack.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only thing Netgear are working on is my nerves.
The NTP must be pointed elsewhere and the traffic measurement function turned off.
They also know as much about how DNS works as the Comcast crew knows (0).
However Xfinity DNS for me is stable and working well at the moment (a miracle no less).
The NTP change with the Channel stats thing turned off has been the deal clincher for me.
It has been very stable since these changes.
Stick with your ISP DNS settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes but you have to do this every hour...very unstable.
@hankster42 wrote:I've been experiencing similar issues since the same firmware release was loaded. The only way I've been able to restore access to the internet, is to login to my Orbi, Select "Internet" then click the "APPLY" button. Within a minute everything comes back online.
Yes but you have to do this every hour and it ain't stable.
Just disable Trafic stats and point NTP to stable NTP instance.
US Navy is solid.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only thing you have to do is disable Traffic Meter. You can enable DST and either use NGs time server or something else. You don't have to do this every hour. Once TM is disabled. All will work normally.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for sharing this info. I made the changed. I will see how it goes.
This is interesting. Firmware check service unreachable.
Netgear fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I disabled the Traffic Meter as suggested and my network has been stable for 2 days now. Seems to have done the trick. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Someone got a beta v105 from NG so there working on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Experiencing the problem has described in this thread. Since the installation of firmware version v2.7.2.104 frequently losing internet access and the only way to restore access seems to be to reboot the router. This is highly disruptive when working remotely. In the year prior to installing firmware version v2.7.2.104 I don't recall ever having to reboot the router. For a novice, what seems be the concensus for a viable workaround until Netgear provides a fireware update that corrects the issue?
Thanks much in advance for an information that can be provided!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have Traffic Meter enabled? if so, disable it:
@hporcher wrote:Experiencing the problem has described in this thread. Since the installation of firmware version v2.7.2.104 frequently losing internet access and the only way to restore access seems to be to reboot the router. This is highly disruptive when working remotely. In the year prior to installing firmware version v2.7.2.104 I don't recall ever having to reboot the router. For a novice, what seems be the concensus for a viable workaround until Netgear provides a fireware update that corrects the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, had Traffic Meter enabled. Have disabled it and will monitor stability.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
how do you disable the traffic meter? Sorry, I am not a tech person, the whole point of doing the Mesh network in the first place was ease of use and not being a tech person!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@TFuser wrote:how do you disable the traffic meter? Sorry, I am not a tech person, the whole point of doing the Mesh network in the first place was ease of use and not being a tech person!
you can use the app (bottom right) or the web GUI -> https://orbilogin.com
