Orbi WiFi 7 RBE973
Reply
Orbi RBR50 guest access showing unsecured network
dbarry6
Hi,
I have the Orbi system with the RBR50 and RBS50 running firmware 2.0.0.74.  I am trying to enable guest mode with a password.  When I select to enable guest mode and choose to have WPA2 password required I get a guest network that requires the password, but there is another guest network with the same name that does not require a password.  I do not understand why the one guest network with no password is being broadcast.  Let me know if anyone has any suggestions.  Thanks.
Dennis
Message 1 of 4
Accepted Solutions
nholobo
Initiate
Re: Orbi RBR50 guest access showing unsecured network
Hey Dennis,
I literally just ran into this issue this morning. I'm getting ready to host some people at my house and I wanted to enable the guest feature.  I just ran into the same issue and I got around it with the steps below.  I'll give some background as to how I turned it on to see if it helps make sense of your issue.
Background:
Rather than grab one of my computers and use the web interface, which I prefer, I used the Orib app on my phone to enable the guest network.  I was seeing two of the same SSIDs (one protected and one open).  The two networks only appeared on my phone.  Two of my computers only saw the protected network.  I turned off the guest network and the SSIDs were still being broadcast.  Now I'm annoyed.
Steps to solve (I used the web-interface on my laptop exclusively as I suspected an issue with using the mobile app):
1. Turn off Guest Network
2. Reboot the router -- [Advanced > Administration > Router Status > Reboot (under Router Information)]
--The router came back online and no guest networks were picked up by any laptop or my phone--
3. Enabled Guest network with WPA2 password via web interface
--The settings took just fine and I now have one Guest network that is protected.
I hope this helps you out.  Let me know how you fare.
nholobo
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 2 of 4
All Replies
nholobo
Initiate
Hey Dennis,
Background:
nholobo
Message 2 of 4
dbarry6
Hi nholobo,
Your suggestion worked perfect.  I can now turn guest access off and on with only having the secured guest access be broadcast.  Thanks again for your help!
Dennis
Message 3 of 4
nholobo
Initiate
Glad I was able to help.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2879 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
