Orbi WiFi 7 RBE973
Reply
Orbi RBR50 has deice connect but not showing active
jh3766
Follower
I have 2 cameras current attached to my network. When I go into their settings, they are connected to my homes wifi via the orbi. They are both working properly cause i can access them realtime. When I open the orbi app on my phone and look at the connected devices via webpage, the cameras are not listed as active. Both of them are located in the not active list. I have double checked the cameras mac address and they are the ones listed in the in active list.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
CrimpOn
Guru
Re: Orbi RBR50 has deice connect but not showing active
"Welcome to the Orbi Fan Club."  i.e. this s**t happens and no one has an explanation for it.  (I am a bit frustrated and annoyed that it has finally "happened to me" after not experiencing this phenomenon for 4 years..) It is not the "app".  The Orbi "Attached Devices" logic is faulty.
Message 2 of 3
vajim
Master
don't use the app
IF you must check, login via a PC and even then that's been screwed up recently
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 278 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
