Orbi WiFi 7 RBE973
Reply
Orbi RBR50 keeps losing connection to Internet
willsteez
Follower
For the last two weeks my RBR50 has been losing connection to the internet intermittently. Have tried multiple reboots and even started connecting the RBR50 from scratch. The router is connected to a Comcast router via the cable provided when I purchased the unit and the satellite (only 1) has been connected via WiFi from the Orbi router.
Firmware is up to date V2.7.3.22
Any assistance would be great, just trying to avoid replacing the entire setup.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi RBR50 keeps losing connection to Internet
Does the top ring LED turn ON PINK when this happens?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? IF you have a built in router here, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 347 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
