- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 mobile ph WiFi calling
- Mark as New
- Bookmark
- Subscribe
- Permalink
Started noticing after SW v2.3.5.30
That my household 4 IPhones will call and connect with WiFi calling enabled, however once the other party answers, you can hear them but they are unable to hear you. Really annoying. If we turn off WiFi or WiFi calling (either of the two) only using cell service and not WiFi calling, the calls are fine. I can replicate this every time.
Do do not ask me if I reset my router to default. Yes I have.
I have unplugged my satellite and stayed within direct line of sight to the router, about 4 feet away nothing blocking the router, and still same WiFi calling issue.
May this be addressed in any future update, it is so lame that I have turn of WiFi calling only when I am at my house using ORBI RBR50.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 mobile ph WiFi calling
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
