- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 password recovery
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to log in to orbilogin.com and do not have the correct credentials. I do not seem to remember the password recovery answers. Is there any way to get in short of doing a factory reset and having to reset my whole system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 password recovery
Nope.
If you don't know the password recovery questions (or didn't set them up) and don't remember the password, you'd need to factory reset to get back in.
push and hold reset for 7-15 seconds while powered on
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. Does that mean that I have to set up my wifi names and password again? Or, will it remember any settings from before the reset? I appreciate the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reset clears out all the settings. So simply write down your ssid/password info. that way when you reinstall, you can use the same and devices should auto reconnect.
