Reply
Orbi RBR50 satellite only giving me 1/10th internet speed
CherryBomb666
Follower
I pay for ATT fiber which is 1000 mbps down. When connected to the orbi satellite with a cat 6 cable with the orbi router also connected to the modem (Arris BGW210-700)with a cat 6 cable i'm getting only 120 mbps down. Wifi speeds are the exact same. Router ports are set to 1G Full duplex, and Windows shows a 1.0 gbps connection in adapter properties. I'm curious as to why i'm not getting at least 800 down considering i'm connected directly to the satellite with a cat6. The orbi is in router mode and i've tried all the solutions to somewhat similar problems on the forums such as disabling daisy chaining and what not.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi RBR50 satellite only giving me 1/10th internet speed
Your modem already has a built in router.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
i recommend trying option #3 first.
You'll not see much speeds over 400-500Mpbs on AC. Depending upon designe and support of the wifi adapter or device. Wired LAN cable speeds should be near 900Mpbs at the RBR.
ATT Modems:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994...
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 367 views
  • 0 kudos
  • 2 in conversation
Announcements
