Orbi WiFi 7 RBE973
Reply
Orbi RBR50 shows incomplete list of attached devices
chimpoo
Tutor
I have Orbi RBR50 with firmware version V2.5.1.8. Issue is that it shows incomplete list of attached devices connected. I tried the orbi iphone app and the browser but had the same results. I phyiscally counted all the devices, confirmed with dhcp leases and also through ping sweep app's (e.g fing) to confirm i have over 18 devices but the orbi only reports 5. This was not issue when i bought the system a year ago. Please advise
Message 1 of 8
Accepted Solutions
Guru
Re: Orbi RBR50 shows incomplete list of attached devices
Message 6 of 8
All Replies
Retired_Member
Not applicable
here's your problem:   V2.5.1.8.
Message 2 of 8
theoak
Luminary
I had to downgrade to 2.3.5.30 and then back to 2.5.1.8 to get it to work for me.
Mind you 2.3.5.30 did work from the get go.
Some folks 2.5.1.8 works from the get go; some, not the case.  Folks here either love or hate 2.5.1.8.
Message 3 of 8
Guru
Try a factory reset on the RBR and setup from scratch. Power cycle or reboot all of your connected devices.
Be sure they are all online when your checking the status.
Message 4 of 8
chimpoo
Tutor
How do you downgrade the firmware? Are older firmware available online?
The attached device list is important as i can control screen time for kids etc
Message 5 of 8
Guru
Download from here:
https://www.netgear.com/support/
Message 6 of 8
chimpoo
Tutor
Downgraded Firmware Version to V2.3.5.30 and it's good! I can see all the attached devices now.
Thanks everyone.
Message 7 of 8
Retired_Member
Not applicable
Thanks everyone.
Another case for the bad  V2.5.1.8. ....how many are we up to now??
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1966 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
