- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 suddenly will not go online
- Mark as New
- Bookmark
- Subscribe
- Permalink
My network was fine and as of last night I lost my connection to the internet.
The satellite shows green on the network map but the primary is magenta. I have factory reset and reinstalled with the same issue.
I have changed the Cat5 cable from the modem and rebooted everything as stated in the startup instructions.
the light on top of the master unit is magenta also. Any help would be appreciated.
the modem from my cable provider successfully connects to the internet
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 suddenly will not go online
Can I update firmware if it won't go online?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Power OFF the ISP modem and RBR for 1 minutes, then back ON with the modem first, then RBR. Check the status on the TOP ring LED:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
@Mikerohr25 wrote:My network was fine and as of last night I lost my connection to the internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mode is the modem working in? Router or bridge?
This modem already has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solid magenta following the reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would this current configuration cause this to suddenly stop working after 6 months?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Eventually it is solid magenta following the reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is Circle or Armor enabled?
What does the status say on the RBRs web page under Basic For the Internet status does it say GOOD or bad?
After you log in to the RBRs web page using a web browser, does the top ring turn off by chance?
Was FW updated recently or have you had v2.5.1.8 running for a while?
What mode is the modem working in? Router or bridged? If the modem is not bridged, please try one of the suggestions regarding the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
