- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 throttling connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
The last few weeks (I think it started after the latest two firmwares) the router is throttling the download speed to around 100mbps, and I have a 1gbps fiber. I used to be able to get easily up to 900mbps.
Things I 've tried:
1) Reboot router
2) disconnect everything but one pc
3) factory reset and restore settings
4) factory reset and start fresh
5) verified with two different pcs and 3 different cables
6) I put the ISP's router on and i can get easily to 800mbps.
I am not sure what else to try?
Any help much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 throttling connection
What FW version had you been using when the orbi was getting 900Mb?
Have you tried the Orbi in AP mode with the modem/router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
It was the firmware before the V2.3.1.44, can't recall but I was always downloaded the latest at the time.
The modem is a Huawei Echolife HG8010H and the ISP's router is a Huawei HG659b.
I didn't test the ORBI in AP mode, I can try, but I wouldn't like the idea for long term.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would have been v210 I believe.
And your modem is bridged fully when using the Orbi in router mode? Can the ISP router be removed and use the ONT directly to the Orbi in router mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem can not be removed, but the ISP router has been removed, so it's running full router mode. There are no settings on the modem, it's a "dummy" box to turn the fiber into an ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try going back to v210 and see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I can try that. Do I first downgrade the satellites and then the router or the other way around?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could leave the satellites where they are for now. The RBR is the only item that you Would down grade. If you want to do everything, downgrade the RBR first then RBS since your going backwards in that direction.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No luck after downgrading to V2.2.1.210 either, this is getting frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would contact NG support and ask for help on this. Sounds like something on the LAN side is not working correctly if your not even getting near 900Mbps with a wired connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks very much, how do I contact support? I don't seem to have an option to open a ticket anywhere as I am beyond the 90 days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
A bit of an update.
So the lovely folks on support couldn't find anything that could be causing, so they shipped me a new Orbi thinking the one I had was faulty. I put it on, left everything default, worked fine and I got my speed back (about 920mbps). So then I said instead of redoing everything and having to reconnect the whole universe (I have a **bleep** load of IOT devices) to a new wifi let's reimport the settings of the old router, and boom.. problem is back. However, if I do a factory reset on this one, I get the speed back.
So, it is not a hardware/compatibility issue of any sort, it's something on the older/saved settings. I tried a few different variations but whatever I did, with those settings loaded I couldn't get anything more than 100mbps.
My mind now goes to QOS, as I remember on an older firmware, I was checking something in one of these hidden qos menus, but I am out of ideas of what/how to check it now. Any further ideas maybe?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So with the new system after you factory reset and setup from scratch and do not apply the other FW saved configuration from file and make a NEW configuration and then apply it to the original Orbi system does that system work as expected?
Sounds like a old configuration is not really compatible as it may be causing incorrect configuration and speed slow down.
When was this saved configuration made? With older FW? If so, then it's not recommended to apply that to new version FW systems. As new FW comes out, sometimes the new code makes changes in which saved config files apply for older version of FW however have now become incompatible with new changes. Its best to save off a new config to file at each new version of FW after a reset and setup from scratch has been performed. This ensures each version of FW and saved configuration to file works and helps avoid these issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe comparing an old and a new config from the cli would help identify the issue? I really don't want to reconnect all my WiFi devices from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah, if you did do anything with QoS and your on a 1Gb now, then you would need to factory reset the original system and and set up from scratch and this time, do not touch or enable, QoS, Traffic Meter or Access controls. Enabling any of these seems to slow the system down on a 1Gb ISP service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes it seems I have to go down the route of factory reset. If I keep the same SSID and password on the wifi, would the devices reconnect automatically or they would have to be reconfigured?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes keep the same SSID and PW for wifi and your devices will reconnect fine with out any intervention.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue again after upgrading to the latest firmware. Soft factory reset didn't solve it (reset from inside the gui). However when I did the reset through the hardware button everything came back to normal. This is getting very frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Odd that the UI Erase isn't fully resetting the system. Thanks for letting us know the HW button is.
Save off a backup configuration to file now and label it v60.
