Reply
Highlighted
Tutor
Orbi RBR50 use USB connected Harddisk for TimeMachine backup OSX 10.14
I connected my time machine harddrive to the orbi satalite with USB. The harddrive is visible through smb://readyshare/USB_Storage from my OSX and i can access the data, but it's not available under "Select Disk" in the time machine.
I have created that points to the disk, but i can't choose "Advanced Options" when i do a right click on the share where i could set it as a time machine source.
I can backup when i connect the disk directly to the laptop.
Any help welcome.
Message 1 of 6
Accepted Solutions
Highlighted
NETGEAR Moderator
Re: Orbi RBR50 use USB connected Harddisk for TimeMachine backup OSX 10.14
Hi Patrick_2,
Welcome to NETGEAR Community!
The ORBI's USB port is only for printers with ReadyPrint. It's not available for external storage.
You may raise this query or suggestion to this page :
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
Message 6 of 6
All Replies
Highlighted
Guru
I would contact Apple support for help and information regarding there product.
My Setup (Cable 900Mbps/50Mbps)>CAX80(Modem Mode)>RBK853 v3.2.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 6
Highlighted
Tutor
Thanks for the reply. I would like to have some information if someone has successfully setup a time machine over WIFI USB with the RBR50.
Message 3 of 6
Highlighted
Guru
Might review this:
https://kb.netgear.com/21360/How-to-setup-Time-Machine-with-your-NETGEAR-router
Message 4 of 6
Highlighted
Tutor
Thanks for the reply. I have tried these steps, but the tutorial is outdated and it did not work anymore this way.
Message 5 of 6
Highlighted
NETGEAR Moderator
Hi Patrick_2,
Blanca
Community Team
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2288 views
  • 0 kudos
  • 3 in conversation
Announcements
