Orbi WiFi 7 RBE973
Reply
Orbi RBR50 with 2 satellites adding another orbi system RBK22
GamerwithaDream
Follower
I have a orbi tri-band system (RBR50) in my house currently.  The system seems to drop signal from the orbi router every night that is  hardwired to the modem.  I am not sure if my satellites are to far away from routher, so I bought another orbi system, rbk22.  Can I set both units in that system as satellites even tho one appears to be a router.
Message 1 of 2
Guru
Re: Orbi RBR50 with 2 satellites adding another orbi system RBK22
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 774 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
