- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 with Singtel ONT to ONR upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I need assistance with my Orbi RBR50.
Product Model: RBR50v2
Serial Number: 5R11955B01499
I have previously set it up with my Singtel ONT. I did the VLAN settings and everything was up and running with no issues.
Orbi VLAN setup for Singtel
Today, we did a recontract with Singtel and they upgraded our ONT (Optical Network Terminal) to the ONR (Optical Network Router) and my Orbi is unable to get internet connection from it.
I can connect my 2 PCs directly to the router and get internet connection but for some unknown reason, my Orbi is unable to get internet connection.
Due to this, Wifi is down. I can still use my PCs as they are wired connections directly to the ONR.
I called support earlier only to be told that my complimentary support for Orbi is over and I need to subscribe $75/year for their support. They person I spoke with was still nice enough to send me some email with some help.
MAC Spoofing
But after reading through the steps, I feel like the person I spoke with mistook what I meant because I was advised by my ISP to use Orbi as AP instead.
Even after switching it from Router to AP mode, I was unable to get internet on my Orbi router from my ONR.
I'm lost.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 with Singtel ONT to ONR upgrade
Please do not post product serial numbers in public forums.
If your ONT has a built in router, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
