Orbi WiFi 7 RBE973
Reply
Orbi RBR50
Jshdlr10
Orbi RBR50
Hey guys, I'm a complete newbie to all of this. I was looking for some help and clarity. Hoping someone can help.
I'm hoping to cut as many ties possible with cable and renting equipment. I purchased the RBR50 in hopes of only keeping the internet provider with my own equipment. Do I need any other product to complete my wifi system before returning all of the providers equipment? Is this a one in all product? I have the router and satellite, I believe. I'm very green as you may tell, please excuse me. Thanks in advance!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Retired_Member
Not applicable
Re: Orbi RBR50
You'll need a modem to go with the Orbi router
Message 2 of 8
Jshdlr10
Re: Orbi RBR50
Thank you! That's what I figured, but wasn't sure. Is there any specific I should be looking for in a modem when purchasing?
Message 3 of 8
Retired_Member
Not applicable
Re: Orbi RBR50
Your best bet is to call your Internet provider and ask for recommendations.  If at all possible, stay away from modem/router combos.  They will work, but in my opinion, not worth the headaches.
Message 4 of 8
Re: Orbi RBR50
Very true. But from my experience you can't even guarantee the "they will work" bit.
As suggested, start with the ISP. But, not all ISPs will advise customers on the kit that will work on their networks. They want you to rent from them. Their experience of different brands may also be limited.
Start with the sort of Internet you have. DSL? Cable? Some sort of fibre? A satellite dish?
If your ISP has a user community, like this one, then you might get help there.
Or tell people here was USP iot is, There may be another user.
Then  there are places like Amazon, which sometimes mention ISPs, and may have reviews that say what they are on.
Message 5 of 8
Retired_Member
Not applicable
Re: Orbi RBR50
From my experience, I've been with Cox for years.  Started out renting their modem and later bought my own.  I believe Cox evens lists the modems that they recommend to work with with their network (for what it's worth) on their website.
I would never subscribe to an ISP that forced me to use their equipment that consisted of a modem/router combo.
Message 6 of 8
Jshdlr10
Re: Orbi RBR50
Thank you all for your input.
I have Xfiniity's highspeed which is DSL, I belive.
Message 7 of 8
Re: Orbi RBR50
Google suggests that this could be cable or DSL. So, "I believe" needs confirming.
Is it coming in via a standard telephone line? What modem/router do you have now?
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 917 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
