- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi RBR50
My Orbi keeps loosing connection. I thought this was fixed after the last firmware update but it has started again. Any help with this would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Losing connection in what way? Wifi? Wired? Internet?
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has a factory reset and setup from scratch been performed since last update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Thanks for replying, nut for whatever reason my app said my system was disconnected. I was accessing from my mobile , but when i got home everthing was fine. reloaded my app and seems to be working? Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Please give feedback to the question presented...maybe something going on with app as well.
