- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
IF you got into the RBRs web page, might be a good time to update FW on the RBS first if you can get it to connect and sync, then update the RBR lastly. v70 you have maybe in a bad state. It's been superseded by v102 now:
Use a wired PC and web browser to send the FW files if you choose to update.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Many users are just not that savvy with all this stuff. Part of the reason I’m ok paying for top end equipment by reputable companies so this type of thing is avoided. Frustrating they release updates that aren’t stable or thoroughly tested.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Yes you can use a mac with it's ethernet port.
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
Some updates will not appear on the RBRs web page as being availalble. So users can check NGs download page for FW files to update with.
@NAMetz wrote:
So if anyone is still there, my app works now and shows the router and satellite. The router webpage shows no satellite so if that is the preferred device to update first, how can that be done if it’s not showing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
But as the router was coming back online it gets stuck with a solid magenta ring and when logging in to the web interface I can no longer get an internet connection. I did shut down the router and reboot, but it’s stuck again and can’t get to the internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Power OFF the ISP Modem for 30 seconds then back ON...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
So in the end, seems it was the firmware that solved the problem by updating, but what an ordeal.
Thanks to all who helped along the way...saved me $90 for now!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
The laptop MacBook Air that was having issues works now and is connected to the network but doesn’t show up at all so far. I’ve refreshed a few times but nothing. Guess it doesn’t matter if it’s working but seems odd.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed again.
Please mark your thread as solved so others will know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Well I believe this was marked "SOLVED" so not sure if this is the right place to reply again, but more issues this morning after the upgrade to the latest firmware (v102) and rebooting everything. At this point the devices being used seem to work and are connected to the internet.
However, I was on the router webpage interface checking things and in the access control section I started to see devices showing up as "Blocked". No idea why and I checked them or went into edit and changed to "Allow". Not only did that not work but each time I refreshed at least one more blocked device showed up.
After a few of these attempts to allow those blocked devices, access to the router web page interface is now denied. When I type in the 192.168.1.1 on this computer, I get the red/black screen saying the "Device is Blocked by Access Control". How is that possible when it's the actual router page!
I then tried to log in to the router page on my iPhone and it worked fine. So at this point my Windows laptop has somehow prevented me from getting to the router interface page. On my phone now it shows about 10 of the 37 devices blocked, including the laptop I'm on but other than the router webpage, I can access whatever I want.
Going to monitor but any ideas on what is going on is appreciated. Should I just turn Access Control off? I really don't have a need for it as far as I know, need to research "why" a bit more I guess.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
I would disable access controls if you don't have a real need for it. Mines disabled. Possible that there maybe some issues with Access controls if you had it enabled prior to FW updates.
You only need to reply once for your solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Thanks, I will try to disable and see if that clears things up. Should I reboot the router and satellite after those kinds of changes?
So it's ok to reply to posts after they are solved? Just don't want to cause confusion or break community rules.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
Yes, however I prefer powering OFF for 15 to 30 seconds then back ON after the change is applied.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50
...and as I stated before.....Keep something else in mind, sometimes when rebooting the router and satellites you need to leave it alone for several minutes. Especially with the number of devices you have on your network
- « Previous
- 1
- 2
- Next »
