Reply
Orbi RBR750 Backhaul Connections Reported Incorrectly
orbiuser1975
Just installed a RBR750 router/satellite system. Both the router and satellite have firmware V3.2.16.22_1.4.9. The satellite backhaul connection is via CAT5e through a switch (not direct).  Couple of questions:
1. I have noticed from the app that all devices connecting to the satellite are showing up as "wired" connections on the router. Will this ever be addressed to show appropriately as "wireless" connections on under the satellite?
2. The guest network option is enabled and guest network connection through the satellite don't show up guest network connections, but rather "wired" connections through the router. Will the incorrect reporting for guest connected devices be addressed? This one just stumps me, as I can see the guest connected devices are on a different subnet, so should be easily determined as "guest" even though they come through the wired backhaul.
Message 1 of 5
Accepted Solutions
alokeprasad
Mentor
Re: Orbi RBR750 Backhaul Connections Reported Incorrectly
Please post in Orbi 6 forum
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
FWIW, I have seen posts here (for lesser Orbi systems) that power-cycling the base router sometimes fixes this.  But I could be all wrong (I haven't experienced or fixed this myself).
Orbi RBK50v2 ver 2.7.2.104
Love my Orbi (with this firmware version).
Message 2 of 5
All Replies
alokeprasad
Mentor
Message 2 of 5
orbiuser1975
Thanks, marked as accepted and reposted in Orbi 6.
Message 3 of 5
alokeprasad
Mentor
For a moment I thought that my power-cycling suggestion worked Smiley Happy
Message 4 of 5
orbiuser1975
Unfortunately, no, but I did try.  Thanks.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 272 views
  • 0 kudos
  • 2 in conversation
Announcements
