Reply
Orbi RBS20 Satellite Eithernet Ports
PhilHelp
Initiate
I have an Orbi RBK 50 with one satellite. I need to hard wire another satellite to my steel building shop that is 130 feet from my Orbi router. Are the eithernet connection ports on the back of the satellite for input or output or both?
Message 1 of 3
Mstrbig
Master
Re: Orbi RBS20 Satellite Eithernet Ports
Both.
After setting up the satellite, run a cable from one of the LAN ports on the RBR50 and connect it to a port on the back of the satellite. It will automatically go from wireless to wired backhaul. Make sure yuo run at least Cat5e cable.
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 2 of 3
Guru
I recommend running buried CAT6A from the home to the shop. CAT6A is more robust and would be best if burried.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 163 views
  • 0 kudos
  • 3 in conversation
Announcements
