Orbi WiFi 7 RBE973
Reply
Orbi RBS40 Bricked after Automatic Firmware Update.
AndyGreenleaf
I noticed that one of my 2 RBS40 stopped working.  I then looked and saw that the RBR40 and the working RBS40 had auto updated the firmware.  I thought I had auto update turned off, but I digress.  The attempt to upgrade this RBS40 to the new firmware V2.2.1.210 appears to have bricked my satelite.  I have tried the manual TFTP upgrade for that unit multiple times, using both a Mac and a PC. Nothing seems to unbrick this unit.  Suggestions?  Netgear support, should this be RMA'd?
Model: RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 4
Guru
Re: Orbi RBS40 Bricked after Automatic Firmware Update.
Probably best to contact NG support and ask for an RMA.
@Christian_R
Message 2 of 4
AndyGreenleaf
Unfortunately, because I bought the product over a year ago, I can't get support to talk to me.  Not sure how I might go about that.
Message 3 of 4
Guru
Send a PM to @Christian_R and see if he can help you. Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 845 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
