Reply
Highlighted
Follower
Orbi RBS50 firmware at V1.4.0.18 I need the img files to update it
I have an Orbi Satellite with firmware at  V1.4.0.18. I understand I need to get img files supported by this firmware to manually udate it to get it to par with the rest of my network. Please advise where to get the files. Thanks.
Message 1 of 2
Accepted Solutions
Highlighted
Guru
Re: Orbi RBS50 firmware at V1.4.0.18 I need the img files to update it
All downloadable files are here:
https://www.netgear.com/support/product/RBS50.aspx
You first need to apply v2.0.0.74, then you can go directly to v44.
Connect a wired PC to the RBS and wait for the PC to get an IP address from the RBS. Log into the RBS at 192.168.1.254 with a web browser once PC has an IP address then send the FW files to the RBS.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
All Replies
Highlighted
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 342 views
  • 1 kudo
  • 2 in conversation
Announcements
