- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBS50 reboots everyday
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi mesh network... and it has this reboot problem - approximately every day it rebots. Recently I internet supplier upgraded their router and I hoped that would solve the problem ... and for 6 days it worked without rebooting. Now it is back to its normal behaviour of rebooting at random times at least once a day.
I have read the forum - and if you have this problem Netgear has replaced the product ... My problem is that I bought this system in 2018 and I am out of warantee... so I called Netgear to ask about sending it in to them for repair. But no: Netgear do not repair their product - and the suggestion is that I should throw this product away and buy something new... and the person on the phone could help me make a choice of their new equipment.
Personally I find this outrageous. This is expensive kit - clearly there is a design fault that leads to this rebooting issue - but netgear wash their hands of it
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just a small update...
On my ISP router I have enabled DMZ mode that points to the address of the Orbi (192.168.1.10)
On the Orbi I have set it up as a router - and it shares adresses in the family of 10.0.0.1 etc...
The system has now been running 6 days without a problem and without a reboot.
I have also enabled the wifi network on the ISP router (as a backup in case of problems) - and this does not appear to disturb anything.
On the ISP router I have also attached a computer on a fixed address (running linux) that I need to log into from outside - and this continued to work - I have also an internet telephone on the router of the ISP.
The key appears to be using a fixed address for the Orbi - and running the Orbi as a router.
Many thanks to FURRYe38 for their insight.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBS50 reboots everyday
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the useful information
Firmware V2.7.3.22 (GUI language version V1.0.0.375)
The router supplied by the ISP is a Icotera Model: i4850-00.
The problem I have is that the walls are ~ 1 m thick stone and the Orbi satelites can talk through the wall when they are placed each side...
The reboot usually happens when I am connected to the server unit - and happens during video calls - and this makes it very annoying. I have enabled the WiFI on the Icotera router with a different Wifi name - and this works without problem [i.e. never hangs] so I can join that network if I am making a critical video call.
Each firmware update I hope that Netgear would solve this problem. I have tried many variations to try and find a solution to this continuing rebooting - but so far I have failed. I am not alone with this problem and I would have thought that Netgear would either offer a hardware fix - or fix the firmware - instead their service department say that I should throw it away and buy something new : unbelivable.
I will go through your list of suggestions ... but I fear that there will be no magic solution
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mode is the modem working in? Router or Bridge?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You might try option #3...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for this suggestion re the AP mode (option 3) I will try this ... 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did not see mention of the electrical supply to this Orbi.
- Is it on any sort of UPS?
- Has the power supply been swapped with a satellite power supply?
- Has the power supply been plugged into a different outlet?
My Orbi has been in operation for 126 days. Even my hyperactive imagination cannot come up with an explanation for what would cause a router to spontaneously reboot. besides losing electrical power.
In a post on a different subject, I saw mention of a Panic Log. There is an option on the orbi debug page (http://orbilogin.net/debug.htm) to Start debug log capture on boot up. The option to Save debug log will copy a zip file to the user's computer. Inside the file debug-log.zip there are many (many) files, and one of them is panic-log.txt (Mine is empty)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let me give an update ... and now I am more confused than ever:
In AP mode ... everything was fine - except that after 1.5 days the system rebooted ... then continued to run for another day... then it entered into a very strange mode: my iphone was connected to the main orbi router by wifi and it was fine (I did an orbi speed test and it showed everything was well 1 Mb/s download and upload)... but my computer (macbook pro) had bad problems: very slow internet speeds to update a web page (maybe a minute or two to display the bbc.co.uk page)... When I switched to the WiFi from my ISP router box - they were also very slow (but the iphone had no problem). I switch ed everything off and back on - and everything rebooted: just after this action - things seemed fine ... but after a minute or two it returned to the previous state.
I switch the AP mode off on the Orbi (going back to 'router mode') and I could logiin to the Orbi - but it was not talking to the internet. The only solution was a factory reset... and I left the Orbi in the default mode. This was fine - internet speed was normal for all connected devices (but during the night the Orbi rebooted itself twice).
I will investigate more ... but this Orbi system is driving me crazy ... I would like to love my Orbi ... but I suspect that I will have to accept the once a day reboot - and to use the wifi from the ISP router for critical use.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try suggestion #2 if you put the Orbi back into router mode while your ISP modem is in router mode as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear Furrye38
Thank you for your help and interest. I have now set up option 2. At least it has run for 12 hours without rebooting so I live in hope. 😊
I will update later after more time has passed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
