Orbi WiFi 7 RBE973
Reply
Orbi RBW30 Antennas
Orbi RBW30 Antennas
Are the antennas in the wall plug RBW30 satellites omnidirectional? Does it matter whether they are plugged in vertically vs. horizontally?
Model: RBK33| Orbi Plug-In WiFi System
Message 1 of 7
CrimpOn
Guru
Re: Orbi RBW30 Antennas
My brief search did not turn up a "picture" of the RBW30.  (I am not a great searcher.)
If you already have one, it should "come apart" easily with a small Phillips screwdriver.
What we think of as an "Omni-directional" antenna typically refers to a "do-nut" shape, where there are distinct "dead zones" at the exact top and bottom.
Message 2 of 7
Guru
Here is what the RBW looks like inside:
https://apps.fcc.gov/eas/GetApplicationAttachment.html?id=3333993
Message 3 of 7
CrimpOn
Guru
Is there a secret to get access to this web site?  I get a "Not Authorized".
Message 4 of 7
Guru
Hmm worked yesterday,
Try this then select Internal Photos:
https://apps.fcc.gov/oetcf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&RequestTimeout=500&called...
Message 5 of 7
CrimpOn
Guru
Thanks for the link to pictures.  It appears to me that there are two sets of antennas at the top. One set oriented vertically and the other horizontally.  So, it might not make any difference which direction the RBW30 is plugged in.
Message 6 of 7
Guru
I presume not. As long as the unit is getting air flow. Smiley Wink
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1693 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
