Orbi WiFi 7 RBE973
Reply
Orbi RBr50 need to completely restart account
Thutchins
Follower
I need to restart my Orbi from scratch. The email that I used years ago when setting up net gear account is no longer active. So I want to start all over and create a new account and setup my ORBI with that new account. Does a factory reset wipe all info from the unit so I can start new?
Thanks!
Message 1 of 2
CrimpOn
Guru
Re: Orbi RBr50 need to completely restart account
After a Factory Reset, the Orbi can be set up using the Orbi web interface (http://orbilogin.net) It does not use the Netgear account login at all.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 295 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
