- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Router NBN Dropouts
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I'm hoping that someone will be able to help me. I recently purchased a new Orbi RBR50v2 system (the two pack, one router and one satellite).
My current setup is the Orbi router plugs directly into my NBN box (the uni-d port) and I have the satellite at the other end of the house. I have FTTP NBN, IInet is my service provider. I have no other router / modem hardware in my system.
I've been experiencing a large number of dropouts. These aren't wifi dropouts, they are NBN disconnections / dropouts. I have checked my connection log with my ISP and before I connected my Orbi (when I was just using my ISP supplied Wifi router) my connections were lasting weeks at a time. After connecting my Orbi, my connections are lasting between minutes and hours, often with dozens of disconnections and reconnections per day. I don't think it is an ISP issue as the problem started on the same day I connected my Orbi for the first time.
Has anyone come across this before? Are there any settings I am missing or anything that I can change to fix the disconnection issues and make it stable.
Appreciate the help. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Router NBN Dropouts
Is the Orbi system operating in Router or AP mode?
Does both wired and wireless connections fail during this dropout?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
