- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Router RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just bought and installed a new modem to my internet service. Afterwards I discovered that my orbi router is no longer on the same network. I tried to go to the router loginpage for orbi to add it to my new service but since I am no longer on the same network I cannot access. Is anyone able to help me connect my orbi to my new network? Thanks so much.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
First of all thank you for helping me with this.
I installed a Century Link C1100T Wifi Router. I thought it was a modem.
I am following your instructions now. Will let you know.
Thanks again,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Router RBR50
You put the RBR50 in the title and CBR40 in the comments. Which one do you have?
Or if you have both, you can only have 1 orbi routing device functioning in your network. Might be where your problem is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry I didn't catch that the cbr40 popped up automatically.
I have the RBR50 model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What modem did you install?
If its just a modem only device (not a combo unit) try this procedure.
1. Factory reset both devices and power both devices off.
2. power up the modem only with nothing connection. Give it a couple minutes to fully boot.
3. After its fully booted, connect the modem to the wan port on the orbi. then boot it up. Give it several minutes to fully boot.
4. Try redoing your orbi installation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well it looks like it worked!
Thank You!!!! And I thought I would have to go into the Orbi and create new user names and passwords but it looks like the 2 I have are still there and working. I am so grateful to you plemans Master!
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are running a combo device and the orbi in routing mode, you might run into a double nat situation.
https://kb.netgear.com/30186/What-is-Double-NAT
Basically you'd need to put your orbi in AP mode and shut off wireless on the combo device to fix the issue
