Tuckerdude
Apr 04, 2017Tutor
Orbi Router in AP mode (setting fixed IP address)
Hello everyone...
I'm running the Router in AP mode and mostly pleased with how it's all working. However, I would like to be able to set a fixed IP address for it so that I can always find it if I need to do some "admin" stuff on it.
The problem is that the Lan Setup portion of the interface is greyed out which I'm pretty sure is telling me that I have to be in Router mode to acess it. But before I go and make a bunch of changes, I just wanted to ask the following:
Is the fact that the router is in AP mode the reason that it "REQUIRES" DHCP? Meaning, you cannot have a fixed IP unless you are in Router Mode?
And FYI, I'm currently a COMCAST customer using a Business Class modem in my house, and it's using the 10.1.10.1 range of IP adresses and serving as the router for the entire house.
Any help or thoughts on this would be much appreciated.
- st_shawMaster
You should be able to acheive what you want by setting a "reserved IP address" for the Orbi in your existing router's DHCP settings. The Orbi will still receive the IP address via DHCP, but it will be the same address each time. You will need to know the IP address of the Orbi to set this up in your router.
I'm not certain, but you might be able to set Orbi to a fixed IP in Router mode, then switch back to AP mode. The above method is better though, because you control all your IP addresses from your existing router/DHCP server.
Hey St_shaw...thanks for the response!
I went to my routers web interface but could find no facility to do as you described. It's a Comcast Business Gateway (router) and there are limited options/features available to me.
Yeah, I thought about your second method as well, but thought I would ask this community first before going in a screwing up something. I'm also concerned that if I make changes to the IP address on the base, that then the Satellite won't see it anymore? I guess it would probably require me to "re-bind" them, but I guess I'm just paranoid.
- st_shawMaster
It's possible the router doesn't have the feature. That would be a pretty poor feature set though.
You will not screw up anything if all you do is change the IP address from DHCP to static. You can just set it to the same IP it's on now. To be extra careful you could set the Orbi IP to be outside the DHCP range used by the Comcast Gateway. The default DHCP range is probably something like .10 to .199. You should be able to find this in the Comcast GUI.
I don't think you will affect the Orbi base/sat connection. That's done over the 5 GHz backhaul.
