Reply
Orbi Router reset to factory defaults, lost my entire configuration!
DougB628
Apprentice
I was experiencing some problems with slow wifi (speed test under QoS was showing accurate available speed 200+ down, 20+ up), Apple TV was getting highly variable speed as low as 5Mb up to maybe 30Mb. So I decide to restart my router. When it comes back, I have a WiFi network called ORBI27, and when I go to 192.168.1.1, it's taking me through the new setup wizard. I lost my entire configuration, all my device names, etc.
Running firmware V2.2.1.210. Was going to consider moving to new firmware (if its still available), but needed to log all my my configuration (which completely sucks by the way - Netgear, that's directed at you!)
I intend on taking advantage of this to upgrade to the newer firmware, since I lost my config anyway...
Has anyone else ever had a "random" factory reset?
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 19
raven_au
Virtuoso
Re: Orbi Router reset to factory defaults, lost my entire configuration!
Yes, but it only happened to me once a very long time ago.
Message 2 of 19
CrimpOn
Guru
This sounds alarming.  So, exactly how was this restart accomplished?  Unplugged the power and then plugged it back in again?  Used the "Reboot" option on the "Advanced->Home page"?
I love my Orbi.
Message 3 of 19
Before this happens again, create a backup of your settings, if you haven't already.
  • Advanced
  • Administration
  • Backup settings
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 19
DougB628
Apprentice
The main reason I had not done this already is that you cannot rely on a configuration backup being usable after a firmware upgrade. This is one of the things that I (and many others) find so frustrating - pretty much all router makers don’t care about their users enough to solve this problem. It IS solvable - document when you change things, and save config backups in a format that can be edited by a user.
Message 5 of 19
ekhalil
Master
@DougB628 wrote:
.................. So I decide to restart my router. When it comes back, I have a WiFi network called ORBI27, and when I go to 192.168.1.1, it's taking me through the new setup wizard. I lost my entire configuration, all my device names, etc.
This should not really happen!
Did you may be happen to press the reset button for long?
To backup and restore my data I use telnet which really makes my life easy! 🙂
I print all device names, types and IP reservations to be used when needed!
Please check here: https://community.netgear.com/t5/Orbi/Quick-way-to-re-enter-your-IP-reservations-after-factory-reset...
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 6 of 19
DougB628
Apprentice
I never touched the reset button - I pressed the power button, unplugged power, replugged power, then pressed power again.
Thanks for the tip on re-entering DHCP reservations. Although I have found that when I restart my Orbi, sometimes there is something wrong with its DHCP responses that devices don’t “see” it and keep asking for an IP. So I will be switching to DNSMasq ona Raspberry Pi soon. I’ll get the benefit of DNS caching too.
Message 7 of 19
That is true. But you lose nothing by having a backup and restoring your saved settings after an update.
More often than not, the retrieved settings will work fine. If they don't you have lost  nothing. Simply reset the thing and reconfigure from scratch.
Message 8 of 19
mkepeter
Guide
I just stumbled on your post.  I purchased a new Orbi (RBK30) system 2/1/19.  The past two auto firmware updates have reset my router to factory default settings.  My contacts to support have yeilded nothing.  They've stopped replying to me.  How are things going for you?
Message 9 of 19
DougB628
Apprentice
I did have it happen one more time. I’m on .44 firmware now, but I think I’m going to go back to the older .210 because my connections are less stable and slower on this version
Message 10 of 19
I wonder if we are talking about the same thing here as in this discussion:
Re: Orbi RBR20 Losing Configuration - Page 3 - NETGEAR Communities
Message 11 of 19
Guru
You might try a re-load of the v44 FW files using IE11 or FF browser, factory reset and setup from scratch.
Also someone did a 30-30-30 reset as well which seems to have solved this problem on there system.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX800 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 12 of 19
cibola
Yes. I'm on the latest firmware before anyone asks. It will stay up for a minute or 2 minutes the spontaneously reset to factory. No solution yet.
Message 13 of 19
Guru
Message 14 of 19
Jestas
It just happened to us today.  Do we need to go through an entire setup again?  This is a huge issue, resetting all connected devices in THEIR apps - Sonos stereo systems being the biggest issue.
Message 15 of 19
Guru
Be sure when you get the system back up and running completely, do a back up of the config to file on the RBR for safe keeping.
Message 16 of 19
Not just "someone". Several people have reported that this works.
Better yet, they have saved and restored their settings and they stick without resurrecting the bug.
No harm in trying it.
If it does work for you, please report back so that we can add it to the repertoire of solved issues.
Message 17 of 19
Guru
Glad it is working for Several others. Smiley Wink
Message 18 of 19
Blanca_O
NETGEAR Moderator
Hi All,
For those who are still having this kind of issue after reloading the firmware and reset (30-30-30), please PM me.
Blanca
Community Team
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 6667 views
  • 4 kudos
  • 10 in conversation
Announcements
Orbi WiFi 6E
