- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi: STAY AWAY!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Come to find out this happens anytime I go to a website that asks for login information. My old router does not do this and it doesn’t happen when I use cellular data. WTF is this? Did this thing come infected with malware, pretty much straight out of the box? Was it included in the firmware update? What a joke. I knew I was in trouble when I had to download an app just to use this thing.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is not a Orbi nor a security or hacking malware issue!!!
There a built in router here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi: STAY AWAY!!
- There is no need to download an app to install and use an Orbi. That option is included (a) because everybody else offers it, and (b) customers seem to want it. I always use the web interface to set up WiFi routers, including the Obri.
- During the install, did you activate Bitdefender Armor (in the app, it is called "Security")?
That creates "additional protection", a feature that I declined. - What URLs do you enter to connect to these sites?
If the login page is "http" rather than "https", then yes you are sending account information "in the clear."
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple of options,
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jamckeon88 wrote:
I got this router with one satellite yesterday. This morning when I go to log into my ATT account to pay my bill... I’m redirected to this ( see attached picture)
Did you purchase the new? If not I suggest factory resetting it before you do anything.
If new, do not setup Armor or Circle, as that may be your issue.
I can vouch that the Orbi line is one of the best available. So your issue is propably related to settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
