Orbi WiFi 7 RBE973
Reply
Orbi Satellite Addons
RudigerGatt
Hey everyone, ive been researching alot about mesh networks, im moving into my home soon which consists of 2 floors. Ive seen a number of reviews and from the looks of it the nergear orbi is the one :). im going for RBK 50 which consists of 1 router and 1 satellite, if when i purchase this not  enought and i just want to extend slightly, can i buy any satellite model, by it the orbi plug too?
Thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 5
mgdurand1
Luminary
Re: Orbi Satellite Addons
I have a fairly large 2 story as well.  I have quite a few devices and some thick walls, and I wound up with 3 satellites.  All work very well together and I am pleased with the Orbi system.  If oyu don;t need strong signal in every room the current configuration you have might be sufficient, but I needed signal in every bedroom upstairs (lots of guests, etc).  Hope that helps.
Message 2 of 5
Guru
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
I have a 5000sq ft home and use just the base and 1 satellite with 40 feet in between. Have great coverage and performance.
Message 3 of 5
RudigerGatt
The house is a total of 4000sqm, its not all open plan. If i did buy the 2 system package and needed another satetllite, could i buy any orbi satellite or does it have to be a specific model like my package?
Message 4 of 5
Guru
It's best to keep similar model satellite to maintain same wifi speeds across the board. However you can connect different model satellites.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1001 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
