Reply
Orbi Satellite Connected As Daisey Chain Topology
MNJ
Follower
Follower
I have a router (router1) and satellite (satellite1) as my wifi network.  How do I add a second satellite (satellite2) as a daisey chain (satellite2 --> satellite1 --> router1)?  Clear instructions please (step by step as though I am new to networking).
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 2
Guru
Re: Orbi Satellite Connected As Daisey Chain Topology
Be sure Daisy Chain is enabled on the RBR.
Placement of the RBS is key. Out in a line:
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
With the RBR already on, Turn ON the nearest RBS to the RBR first. Let it sync. Then turn on the farthest RBS thats nearest the other RBS. Let it sync. Should all connect.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 77 views
  • 0 kudos
  • 2 in conversation
Announcements
