Reply
Highlighted
Orbi Satellite Disconnects on Youtube videos
I have a simple orbi set-up going - one router, one satellite.
Only when I watch videos on youtube, my satellite will crash (no devices can access the internet even when connected to the SSID) until the satellite is turned off. Other streaming sites work no problem (Netflix, Plex), it's only on youtube videos. How can I troubleshoot this issue?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Highlighted
Guru
Re: Orbi Satellite Disconnects on Youtube videos
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 529 views
  • 0 kudos
  • 2 in conversation
Announcements
