- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Satellite RBK50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why my Orbi satellite-1 in the Backhaul Status shows POOR?
this satellite is about 30 to 35 feet from the main Orbi base
my home is about 1750' sf
my internet speed is 120 mb
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Satellite RBK50
What kind of building materials is your home made off? wood or concrete?
Single story or multi?
That size of home, you can use the router alone if placed centraly in the home and should cover have good signal range
- Mark as New
- Bookmark
- Subscribe
- Permalink
the house is in concrete, the main unit is in one corner of the house and the sattellite is in one bedroom basically in the midle of the house.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's the signal strength from the router at the satellite location on the upper 5ghz band? Are other Wi-Fi networks using the upper band?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That isn't signal strength its measured in db. If you have an android there are tons of wifi analyzer or a laptop with InSSIDer
- Mark as New
- Bookmark
- Subscribe
- Permalink
My satelite is also shown backhaul signal poor.
Mine is not even on 5G band for the backhaul
Does anyone know how to set the backhaul band?
I am on firmware 2.1.4.10
satelite is 30feet apart from the router, building material is wood stub and sheetrock
- Mark as New
- Bookmark
- Subscribe
- Permalink
There doesn't appear to be a way to set the backhaul, maybe through the command line there is. Use a wifi analyzer (android unless apple finally opened this capability) or InSSIDer on a PC to look at the upper 5ghz band (the unnamed one is the backhaul). if your neighbors are using that band then good luck.
I would like something better from Netgear about the decibel requirement for the satellite (better than good or poor). When I set a 2 7800s together, I can tell link speed. I keep debating about putting a 7800 behind the TV to test if a RBS50 would make sense, but the firmware doesn't access the backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check to see if daisy chain is toggled on or off. I had that experience one time on an update where daisy chain was automatically toggled on and I had a poor backhaul on one of my satellites. Not that daisy chain mode causes it, but one or the other (on or off) could be better for the backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I didn't buy the 2nd satelltite yet. trying to figure out if it would do any good. less than 20 feet through the floor from the satellite. no duct work in the way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don’t know if this helps... normally the satellite link in my House is ‘good’ but today trying to solve a problem where a distant device was not connecting I turned on beam forming under the advanced settings. This solved the problem with the connection I had, but then I noticed the satellite link was now ‘poor’. Having said that performance is fine, and there are no LEDs lit on either orbi. I wonder if there is a bug in the connected devices display??
- Mark as New
- Bookmark
- Subscribe
- Permalink
I raise the satellite about 4 feet more and turn it off and back on again and I see the status changed to GOOD. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, concrete will not be good for 5Ghz due to it's high frequency.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I noticed the same thing with the indicator on the backhaul especially if you have a poweroutage & lets say the satelites come up before the router they will show poor in the attached devices screen.. the only way I saw to fix this was to reset the router, then after that unplug the satelites and one by one plug them in.. once you do that at least for me they say good.. however if one looses power or one is moved too far once the status changes to poor it never changes back to good. I do think its another bug lol
