Orbi WiFi 7 RBE973
Reply
Orbi Satellite RBR50 Not Connecting via Ethernet
TomLokey
Tutor
Was previously able to access my RBR50 settings via ethernet connection by going to orbilogin.com.  Recently purchased new laptop and now get error screen saying I'm not connected to the Wi-Fi network.  Have tried suggested corrective action and several browsers without success.  I am able to access the router using the Android app.  Any suggestions for connecting via my laptop?  Thank you.
Message 1 of 6
Accepted Solutions
TomLokey
Tutor
Re: Orbi Satellite RBR50 Not Connecting via Ethernet
Thanks to all.  Finally found an ethernet conflict in Windows settings, and all's right with the world.
Message 5 of 6
All Replies
ekhalil
Master
Is your new laptop connected to Wifi or Ethernet to Orbi? Can you browse to any other site from your new lapop?
Message 2 of 6
TomLokey
Tutor
I've tried accessing the Orbi configuration with my laptop using both Wi-Fi and hardwired ethernet connection, and neither works.  And yes, I am able to access every other Internet site I've gone to.
Message 3 of 6
DickDuke
Apprentice
Perhaps you can access the router by browsing to its IP address.
unless you changed it, it will be 192.168.1.1
So http://192.168.1.1 will bring you to the login
Message 4 of 6
TomLokey
Tutor
Message 5 of 6
ekhalil
Master
Great that you got this sorted out!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1796 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
