Orbi WiFi 7 RBE973
Reply
Orbi Satellite RBS50 only
calisleo
Follower
Hello,
Can i buy Orbi Sateelite RBS50 only can connected to my exisitng router to use to extended my WIFI
 Thanks
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 3
Accepted Solutions
Reddking
Guide
Re: Orbi Satellite RBS50 only
Unfortunately the answer is no..
You cannot use the Satellite as a stand alone unit. It requires a functioning Orbi Base device such as an RBR50 to function at all..
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 2 of 3
All Replies
Reddking
Guide
Message 2 of 3
Guru
As Redking mentioned you can't use the satellite initially with a different Mfr router.
I have experienced that after a satellite IS connected to a Orbi system via ethernet backhaul first, and you swap out the base router for something else, if you re-connect the LAN cable to the satellite to the new router, my satellite remained working. I presume that at if the satellite was reset to factory, it would not work again untill it was re-synce with the Orbi system.
@calisleo wrote:
Hello,
 Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2836 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
