Orbi WiFi 7 RBE973
Reply
Orbi Satellite Speed 50% of Router Speed
bcbrewster
My download speeds, as measured by speedtest.net are about 50% lower when using the satellites as opposed to the base router. Is this normal behavior? Any way to get speeds through satellites?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Guru
Re: Orbi Satellite Speed 50% of Router Speed
What speeds UP and Down are you getting at the router?
Try ethernet backhaul?
What FW version are you using?
There is Beta available.
Message 2 of 4
bcbrewster
I did a reboot of the router, then satellites. Seems to have worked and they are now consistent: Upload about 120 mbps, download 12 mbps. Will check further later. Thanks.
Message 3 of 4
Guru
Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1610 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
