Orbi WiFi 7 RBE973
Reply
Orbi Satellite connect to another Satellite? Daisy Chain
max911turbo
NETGEAR Expert
I know Orbi Satellite cannot connect to another Satellite but router, however, isn't that you need to be able to do the daisy chain ( Mesh topology) to claim as the mesh system? Can anyone answer my question?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 12
Accepted Solutions
BretD
Admin
Re: Orbi Sattelite connect to anoter Satellite?
If you download the latest version of the Orbi Bios and OrbiOS 2.0 You can now Daisy Chain. Give it a try and let us know how it worked for you. https://www.netgear.com/support/product/orbi.aspx
Message 5 of 12
All Replies
st_shaw
Master
Orbi is not a mesh system.  It's star topology.  All satellites link to the router.
Message 2 of 12
cue003
Apprentice
The Orbi system isn't a mesh system. It is a star topology system at this point. Because it isn't mesh every satellite must connect back through the router and cannot daisy chain to other satellites for increased reach.
Message 3 of 12
max911turbo
NETGEAR Expert
Yes that's what I thought so. Reason why I'm asking was because Orbi market itself as the mesh wifi system which is kind of misleading, so I thought they have different implementation but looks like they don't.
Message 4 of 12
BretD
Admin
Message 5 of 12
andykuww
I don't know how to setup too
Message 6 of 12
DarrenM
Sr. NETGEAR Moderator
Hello andykuww
Are you having issues adding another satellite?
DarrenM
Message 7 of 12
andykuww
I do it today, it’s good, like from router to sattelite, it connect automatic to this method.
Message 8 of 12
rewan
Tried updating the firmware with RBS50-V2.0.0.74
Did not work - said it was not correct for the Orbi
Message 9 of 12
BretD
Admin
Be aware that the different Routers and Satellites have separate Firmware files. Do you have the RBK50 system? This means you would have the RBR and RBS 50 firmwares. Ensure you are using the correct files. Thanks!
https://www.netgear.com/support/product/rbk50.aspx#download
Message 10 of 12
rewan
Yes, that was my problem - I did not notice the single letter difference in the middle of the long filename. Perhaps it would be a good idea to make them more obvious? Especially as they are bothe exactly the same size.
Message 11 of 12
mike34
I updated my Orbi system to 0.74 and it seems to be working fine. I noticed that the satellite no longer shows up on the network map. Is that because it is now daisy chaining or due to something else? The sat is synced. Thanks.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 14630 views
  • 1 kudo
  • 8 in conversation
Announcements
Orbi WiFi 7
