- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Satellite connected, but no data
- Mark as New
- Bookmark
- Subscribe
- Permalink
As soon as I turn it off and my device jumps to the main router.... no problems.
I’ve tried to re-sync several times. I turns “blue” and pops back on as if it is working, but again... no data.
Please advise
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Satellite connected, but no data
Thanks for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
A. What firmware is the satellite on?
B. Have you tried doing a factory reset of the device?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did to a factory reset.
Where would I find/ update my firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just type in the model of the RBS### and this will pull up it's web page with downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Bdeutsch22 wrote:
Thank you for your response.
Firmware update would be under ADVANCED->ADMINISTRATION->FIRMWARE UPDATE.
There's a manual update option there if you decide to go that route
- Mark as New
- Bookmark
- Subscribe
- Permalink
This appears to be the issue.
Now I cannot get a successful update of the satellite firmware . I have tried automatically and manually, with and without hardwiring.
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried logging into the satellite specifically and updating from the satellite's own gui? The attached devices page will show the ip address for the satellite. You can log in there and do the manual update procedure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Besure you have the RBS FW file already on a PC.
You have to LAN wire connect a PC to the back of the satellite.
Press the reset button and hold it in until the top led shows AMBER or start Blinking WHITE. Then let go.
Give about 5 minutes for the RBS to come to ready. The top led will slowly pulsate WHITE.
It may take longer however look at your network status on the PC. It won't show immediately however after a bit, it should get a IP address of 192.168.1.something. The gateway should be 192.168.1.254 or .250.
Which ever number is the gateway, use that address in a web browser while connected to the RBS to access it's web page. Then upgrade the RBS from here.
@Bdeutsch22 wrote:
I found that my firmware on my satellite is not up to date, but my router firmware is updated.
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
HOWEVER... I still have the same issue, if I’m in range of the satellite... no data.
I’m about to give up and just buy a new satellite, but it is about the same price as a new system($275 vs $299)
Thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even after a factory reset on the RBS and re-add there is NO data at the satellite? Even with a wired PC or laptop?
If so, I would file a support ticket as it seems that the RBS needs to be replaced. Ask for an RMA:
https://www.netgear.com/mynetgear/registration/login.aspx
@Bdeutsch22 wrote:
Well... your recommendation on the firmware update worked like a charm!!.... successfully updated the firmware on the satellite.
Thoughts?
