- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Satellite eventually drops internet connect - AC3000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys,
I have recently got myself the AC3000 + Satellite.
Its been working ok besides my satellite. Everything seems ok for a few hours or so then every device connected to the satellite loses internet connection. The orbi doesnt flash or anything just all devices seem to lose internet connectivity. Im forced to reboot the satellite. The router seems totally fine and not had any issues. Firmware is up to date . Anyone got any ideas?
Here are the logs:
[DHCP IP: 192.168.1.9] to MAC address 40:98:ad:af:0b:78, Thursday, May 21, 2020 21:35:50
[admin login] from source 192.168.1.5, Thursday, May 21, 2020 21:34:17
[DoS Attack: SYN/ACK Scan] from source: 51.91.221.110, port 8345, Thursday, May 21, 2020 21:24:10
[DHCP IP: 192.168.1.6] to MAC address a0:51:0b:f0:2f:df, Thursday, May 21, 2020 21:21:01
[Time synchronized with NTP server] Thursday, May 21, 2020 21:20:15
[Time synchronized with NTP server] Thursday, May 21, 2020 21:18:14
[DoS Attack: SYN/ACK Scan] from source: 51.91.221.110, port 8345, Thursday, May 21, 2020 21:16:16
[DoS Attack: RST Scan] from source: 77.247.179.58, port 2710, Thursday, May 21, 2020 20:24:36
[DoS Attack: SYN/ACK Scan] from source: 51.91.221.110, port 8345, Thursday, May 21, 2020 19:38:55
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Satellite eventually drops internet connect - AC3000
RBS using same version of FW version as RBR?
Is the Orbi system operating in Router or AP mode?
