Orbi WiFi 7 RBE973
Reply
Orbi Satellite has solid Magenta in AP mode
pvin2011
Hi, I have an Orbi Satellite RBS20 along with RBR50. I recently changed my ORBI to be operating in AP mode. Since then, my Satellite constantly has magenta led light always on. Apart from this light always on, everything seems to be working. Is this a known bug or as designed?
thanks,
pvin2011
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 6
Guru
Re: Orbi Satellite has solid Magenta in AP mode
May be that the RBS isn't getting an IP address from the main host router.
Power OFF the RBR and RBS for 1 minute.
Is the RBR configured with a Dynamic IP address or Static IP address?
Bring the RBS near the RBR and re-sync them.
Message 2 of 6
Guru
Any progress on this?
thanks,
pvin2011
Message 3 of 6
pvin2011
Hi, I just tried this last night and it looks like after turning off the router and satellite for 1 minute the magenta light has gone out. I will keep an eye out and see if this happens again.
The firmware version on router and satellite is V2.5.1.16.
Thanks,
pvin2011
Message 4 of 6
Mstrbig
Master
Thanks,
pvin2011
Living in arguably the lightning capital of the world, I experience many power brownouts, causing preipherals to reboot, shut down or lock up. Most my gear is on UPS units. But 1 Orbi is not. That one sometimes has the magenta light or reboots and loses all the connected devices, because they redirected themselves to the next closer Orbi. Shutting off and turning back on brings it back up. Half the time the closer devices reconnect. Other times I have to forget wireless network on the device and relogin itno the WIFI.
Message 5 of 6
Guru
Thanks for letting us know. Smiley Wink
Thanks,
pvin2011
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2106 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
