- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Satellite will not reset - no flashing amber light
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Satellite will not reset - no flashing amber light
So unplug the RBS from the power for 30 seconds, Then plug back in. press the reset button for 15 seconds only. Then let go. Does the top ring LED start to blink?
If not, I recommend the RBS be replaced.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh, geez. So, the power LED is green (not "nothing"), you can hear or feel the "click" when the paperclip goes into the tiny "Reset" hole, but the power LED never changes?
If the regular factory reset process doesn't work, @michaelkenward described an undocumented way to get an Orbi to factory reset:
Press paperclip in reset hole for 30 seconds
Keep pressing paperclip while removing power
Keep pressing paperclip for another 30 seconds while apply power
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You got them on the PHONE? Wow! My 90 days ran out two years ago (warranty, too). If mine breaks, it's back to Costco I go.
