Orbi WiFi 7 RBE973
Reply
Orbi Satellite with non-Orbi Router
DNufer
Tutor
Can an Orbi satellite be hooked up with a Netgear router?
The Satellite is: Netgear Orbi Satellite RBS20 for indoor use only
The Router is: Netgear AC1900 Cable Modem Voice Router, Model: C7100V
I was trying and they weren't connecting.  It would be good to know if it's even doable before I try more...
Thanks!
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router, RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 4
DNufer
Tutor
Re: Orbi Satellite with non-Orbi Router
The router is hooked up and working fine.  I just want to be able to add the satellite to it, if it's compatible.
Message 2 of 4
Guru
No. it won't work.
The only satellites that work without an orbi router are the RBS40V and the RBS50Y as they have an extender mode.
Message 3 of 4
DNufer
Tutor
Bummer!  But, thanks for letting me know.  Saves me a lot of wasted time and grief.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1625 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
