Orbi WiFi 7 RBE973
Reply
Orbi Setup-Using my old wifi network name
skyjuice
I'm going to set up my new Orbi system soon.
How do I use my current/old wifi network name so all of my devices(Nest/Sonos/laptops/phones) continue to connect?
Or do I have to start over and rename to Orbi network to a new network name?
Thanks in advance!
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 4
Hydro130
Luminary
Re: Orbi Setup-Using my old wifi network name
I used my previous network SSID and password (for my Asus router), and it worked perfectly fine - all devices connected back on A-OK after finalizing the Orbi setup.
Cheers, Chris
Message 2 of 4
skyjuice
Thanks Chris!
So I assume I will need to keep my Airport Extreme plugged into power so it continues to broadcast ms SSID?
Also, I have two bands, 2.4 and 5ghz. Orbi will naturally select the highest band correct?
Appreciate your response.
-Sky
Message 3 of 4
Hydro130
Luminary
If you are bridging your Orbi to your existing router, I don't have any experience with how that works, sorry.
I myself totally replaced my old Asus router with the Orbi (no bridging or AP setup)  - I just used the same SSID and password when I set up the Orbi.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4679 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
