- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Starter Kit RBR50 (Router Only)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, im looking for a Orbi starter kit (Router only) for my apartmet (1500 sq ft ) built whit briks walls.
I have a question about its solo preformance, if it isn`t working whit a satellite it means that is only a dual band AC1267 (400 + 867) router ? because the other (1733) is for back-haul. Or it can work whit all tri band alone. Or maybe i better just buy a Nightawk AC2300 ?.
To consider we are 3 people: 3 smartphone, 3 laptop, 2 smarTV and a Xbox One. My conexion its 40mb ADSL (its a lot in my country, jaja ). Im looking for strong signal and stability. I dont like to have to restar the router all the time like happend to me whit a Tp-Link some years ago. I just want that work allways and forget that it exists.
Thaks for your opinon, greetings from Colombia.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The backhaul radio is available for the backhaul only. If you buy the router alone with no intention of buying a satellite, you would be paying for an expensive 4x4 backhaul radio that would never get used. If a single AP can provide the coverage area you need, you'd be better off with another solution.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Starter Kit RBR50 (Router Only)
Thaks a lot st_shaw, i will take your advise.
