Reply
Orbi Stops Working Daily
JCRRTX
Follower
My Orbi RBR20 router stops broadcasting wifi almost everyday.  I have to turn it off and restart the router for it to start working again.  I have updated it with the latest firmwater and it still does this.  Any suggestions on how to fix this would be great.
Message 1 of 2
Guru
Re: Orbi Stops Working Daily
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 852 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
