Reply
Orbi - Torrent and DNS problem
zowa
Hello,
I have the following problem:
Orbi (2 units) router mode. When I download something using a torrent client (uTorrent), the DNS name resolution stops.
The network connectivity goes on ok. I can access anything by IP address. And if I configure manually a different DNS server for my computer, it works just fine. The problem is that Orbi just stops wth name resolution.
I have to reboot the units to make DNS work again.
And guess what: I AM UNABLE TO CONFIGURE A DIFFERENT DNS SERVER USING ORBI'S DHCP, BECAUSE IT DOES NOT HAVE THE OPTION!!
Well, any thoughts?
Thanks!
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 16
Guru
Re: Orbi - Torrent and DNS problem
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
I was able to set custom DNS on my friends Orib when setting his up:
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highli...
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 16
zowa
Hello,
Firmware V2.1.4.16.
The orbi is connected to a simple ADSL modem. The problem is not with the modem, because I can connect a laptop to another port at the modem, and it works fine. Only machines behind Orbi are affected by the DNS problem, and only if they are receiving the DNS Server IP Address from Orbi's DHCP.
The Orbi's DHCP configuration does not have an option to change the DNS server provided to clients. Really strange.
My setup:
ADSL Modem -> Orbi RBR50 -> Orbi Satelite (15 feet distance).
Message 3 of 16
Guru
Message 4 of 16
VladAlex
 I am having exactly the same problem (my Orbi router is an AP mode not Router mode so AP mode doesn't resolve this)
Some additional details:
- Only those clients connected to the satellites (wired or wireless) loose DNS. The clients connected to the main Orbi AP (RBR50) keep working properly. Of note, clients connected to any satellite loose DNS (i.e not just those connected to satellite that the system using torrent is connected to). So, this is most certainly a backhaul issue
- Tweaking torrent settings to reduce the download speed\active torrents\maximum number of connections\etc doesn't seem to help
- Using a VPN (configured at the client level not at the router) doesn't help either
- My router (non-Orbi) is my DNS server. I haven't yet tried configuring things to where the router will also avertise external DNS servers to clients in addition to itself
- I use qBitTorrent, haven't tried other torrent clients
- Orbi AP mode is very stable the rest of the time - the problem is isolated to torrenting
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 5 of 16
Guru
Maybe a issue with your main host router rather then with the Orbi. If the Orbi is in AP mode, then its working as a pass thru. Data problems would be needing looked at on the main host router...
Message 6 of 16
VladAlex
While that's possible it's extremely unlikely.
- This issue started happening as soon as I installed Orbi, I didn't have any issues with the router (R8500 running DD-WRT) prior to that point.
- Only clients connected to Orbi Satellites loose DNS - clients connected to main Orbi AP (wired and wireless) and those connected (wired) to the router are just fine. From router's POV, all clients connected to Orbi "look" the same so I don't see how a router issue couild impact only the satellite clients Smiley Happy
It wouldn't surprise me one bit if Netgear was trying to do something smart with DNS queries within the Orbi system and something like Torrent (which opens up a tonn of connections could be impacting things).
Message 7 of 16
Guru
When in AP mode, the Orbi is just a pass thru for network traffic. Orbi wouldn't be doing any kind of network management I don't think...
Message 8 of 16
zowa
It is clearly a Netgear problem. They have a bugged product, and they don't even care to solve it, even with many people reporting it.
Message 9 of 16
mith_it
Luminary
@zowa,
Go to the Web UI of the router, in the basic settings tab click on "Internet" around the middle of the page you will see the menu to manually configure the DNS. Try that one to see if your router is not picking up the dns from your provider.
Message 10 of 16
zowa
It does not matter what DNS server is being used by Orbi. I have tried many...
 The problem is that Orbi stops responding DNS queries to connected devices. And there is no option to change the DNS server distributed do clientes by Orbi's DHCP service.
Message 11 of 16
Guru
You may have just a bad unit. No body else has posted about what your seeing. You might contact NG support and ask for additional help and information and ask for an RMA.
@DarrenM
@Christian_R
Message 12 of 16
Christian_R
NETGEAR Moderator
Hi @zowa
We are currently offering a beta firmware to community members with an RBR50/RBS50. This may solve your issue so if you're interested, please respond to the thread below.
https://community.netgear.com/t5/Orbi/Looking-for-a-select-group-of-Orbi-Community-members-that-are/...
~Christian
Message 13 of 16
Christian_R
NETGEAR Moderator
Hello @VladAlex,
As mentioned to @zowa, we are currently offering a beta firmware to community members with RBR50/RBS50. If you're interested, please respond to the thread below.
~Christian
Message 14 of 16
elocsin
That's incorrect.  I've been dealing with this issue since I setup the Orbi during the summer.  Everything is fine up until I start a torrent client on the machine and after a few minutes of downloading, DNS resolution and ping start to fail.  As soon as I kill the client, DNS resolution and ping start working again.  My old Linksys router never had this problem.
Message 15 of 16
Guru
Possible that your torrent is maxing out bandwidth connection thru the Orbi. Try setting your Torrents downloads to something minimal to start and see if the download problem still happens?
Can you download something usuing a browser from a web site and does the problem happen during a web site download?
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 3717 views
  • 0 kudos
  • 6 in conversation
Announcements
