- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Traffic Meter Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it true that the Orbi Traffic Meter is disabled in my Orbi because it is in AP Mode? Will it function if I change the Orbi to Router Mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Traffic Meter Issue
What is the Mfr and model of the ISP modem? Built in router here by chance?
When in AP mode, most router features are diabled since there not needed and there is another upstream router that would be handling traffic metering if it's supported there. So there wouldn't be a need for any additional traffic metering. You can change the Orbi back to Router mode and enable metering if thats needed.
If your modem has a built in router and you want to use the Orbi router, you can use the modems DMZ feature for the Orbi routers IP address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38wrote:What is the Mfr and model of the ISP modem? Built in router here by chance?
I have a Comcast XB6 gateway TG3482G which is a combo modem/router. And it DOES have a DMZ. Comcast doesn't provide any instructions on how to use the DMZ. About 10 years ago I had a Linksys router with DDWRT and I've forgotten everything.
Here is one Comcast instruction:
"DMZ
Enable a DMZ (demilitarized zone) for a specified device to help resolve communication issues with an online application. Enabling DMZ poses a security risk and should be used with caution. Consider adjusting port forward settings instead."
- Mark as New
- Bookmark
- Subscribe
- Permalink
DMZ only poses a problem if you don't have a device with a firewall. You can use the DMZ for the Orbi router in Router mode, then the Orbi will have it's own firewall enabled and you'd be safe. It's just placing NAT with the Orbi router instead of the ISP modem is all.
It's an option only. Up to users to decide when that have these ISP modem router combos.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38wrote:DMZ only poses a problem if you don't have a device with a firewall. You can use the DMZ for the Orbi router in Router mode, then the Orbi will have it's own firewall enabled and you'd be safe. It's just placing NAT with the Orbi router instead of the ISP modem is all.
Well, that makes more sense to use the Orbi DMZ rather than the gateway's.
So, I guess my steps would be
1. Change the Orbi to Router Mode
2. Put the gateway in Bridge Mode
3. Enable the Orbi DMZ.
Anything else? Do I have the right order?
- Mark as New
- Bookmark
- Subscribe
- Permalink
DMZ is only needed if you can't bridge the ISP modem. So if the modem can be bridged fully, this should disable any router functions on the ISP modem, this would included DMZ. However it the modem can't be fully bridged, then use DMZ on the modem for the Orbi in Router Mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38wrote:DMZ is only needed if you can't bridge the ISP modem. So if the modem can be bridged fully, this should disable any router functions on the ISP modem, this would included DMZ. However it the modem can't be fully bridged, then use DMZ on the modem for the Orbi in Router Mode.
How do I tell if the Comcast router is "fully bridged"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll get a public IP address ##.##.###.### on the Orbi router, not a private IP address, 192, or 172 or 10 something.
